- Jul 10, 2020
- 161
- Plaster
- Pentair Intellichlor IC-40
What tricks do you folks use when you need to clean the pump strainer basket?
I just checked mine and it was riddled with pine needles throughout. By the time I had it clean enough to put back in place much of the water had drained from the filter and it took a repeated , extended effort to get the pump primed and running again. I'm thinking a spare basket would help, and maybe closing off the inlet valves as much as they can (can only close of 1 of 2 skimmers and then the bottom drain).
What do others do to make this less of an ordeal? This will be our first full start-to finish season and I don't remember having this much trouble last year...only having had to do it 1x.
I 've read here about "skimmer socks" also. Are there any recommendations or specific products to avoid?
