Pool Door Alarm
I bit dated, but I think all these are UL 2017
Yard Guard by Smart Pool; model YG03, battery powered, with re-entry switch
Yard Guard by Smart Pool, model YG18, battery powered, and programmable keypad code
Yard Guard by Smart Pool; model YG04, plug-in 120 volt powered,
The Yard Guard alarms generally allow the use of multiple doors or windows on each alarm box. Check package directions for details. www.smartpool.com
Techko Safe Pool, model S 087, battery powered, one window or door
Techko Safe Pool, model S 088, plug in 120 volt powered, one window or door
Techko Safe Pool, model S 089, plug-in 120 volt powered, up to 4 windows or doors.
Techko Safe Pool, model S 187D, battery powered, with additional bypass button for delayed entry from either side of door or fence and low battery LED display. Techko
GRI, model GT10-4 instant on, battery or remote 12 volt DC power, surface or recessed mounted, multiple windows or doors.
GRI, models 289-3,289-4, 289-CP3, 289-CP4, DPARM, DPA-10. George Risk Industries, Inc. | Custom Reed Switch Manufacturing
CITE: https://www.jupiter.fl.us/DocumentCenter/View/4679/Approved-Pool-Alarms-9-24-10?bidId=
Reactions: Mdragger88
SPQ is UL 2017
Ideal Security SK644
Defiant lists as UL 2017 Defiant Wireless Pool Alarm THD-PA
You are in GA and some rules are state specific. While Defiant states they are UL 2017, it does not meet California's requirements for pool alarms. this may also be true for SPQ and Ideal Security. This is because it can be bypassed (turned off) with the keypad and does not automatically reset once activated by an opened door after the door is closed again. The same is true in FL for this alarm for the same reason. I don't know the law in GA.
Information on the product webpage is poor in my opinion. Do any of these products have a master alarm that multiple wireless sensors can be connected to or do I need one alarm box/sensor per window and door? I have 4 total doors/windows I have to alarm and it seems silly I'd need to put one of these large alarm boxes at each one. From what I can tell the alarm portion is about the size of a deck of cards, while not "large...large" I'd prefer not to have one of these at each opening.
As mentioned earlier, check the specific requirements for your jurisdiction. In general, there are two types of door/window alarms that fall under UL 2017: immediate activation or 7-second delay. With immediate activation, you need a bypass switch on the outside to allow entry without activating the alarm. The 7-second delay requires no bypass switch/button since you have time to deactivate inside once opening the door.
I haven't seen any wireless solutions, but I haven't had to search for a few years.
