- Jun 17, 2021
- 29
- Plaster
- Pentair Intellichlor IC-40
Ultratemp installed 1/2021 worked fine until 3 weeks ago. Intellicenter app shows pool/spa heating but Heatpump(HP) unit is in alarm. HP LCD screen is barely legible, mostly black lines, so I can't read the alarms being displayed. I checked the wiring and found the yellow wire to the J2 gas connector loose at the intellicenter control board. I reconnected yellow wire (green wire is ok) and everything started working normal again, except for the HP LCD screen.
HP was working fine yesterday, heating water to 84. This morning I checked HP again because of low pool temp and HP was in alarm. As soon as I opened top pull down door at intellicenter the HP kicked on and started heating the water. I checked all wiring for good connections, nicks and abrasions, and everything checked out ok. I went to use the spa this evening. App shows water at 83 and I have it set to 98. After 30 mins water was still 83. I went to HP and it is again showing a red alarm. It's dark now, so I will be troubleshooting tomorrow. Has anyone else experienced these intermittent symptoms?
