OmniPL Google Home Integration in 2025
tech135797531
59
FL
Has anyone found a way in 2025 to integrate the OmniPL with Google Home as Hayward said from release that would be possible? I called support, they said that someone would call me back which never happened, I searched for it, nothing. There are some instructions on how you may integrate it with Home Assistant but it seems cumbersome and a bit of a long shot.
Logging into https://haywardomnilogic.com you can still go to Settings > Nest (Works with Nest) and click Login to Nest, but Nest has been gone for a long time. So this also tells me that Hayward is not putting any effort whatsoever into this interface, I mean it would have a 10 year old 5 minutes to hide a button and tab.
Anyway, any ideas or should I let go of this?
If that's the case, it's a real shame. I guess I will have to figure out how to hook it into Home Assistant, and then I use Nabu Casa to tie Google Home into Home Assistant without giving Google unfiltered access to all my devices. It's the right way to do it, I was just curious if Hayward tried to make it right.
