This flow meter was installed new in early June. Are you advising that it would be a good idea to remove it and clean it to see if the reading improves? Is it enough to just open the valve at the top and let water flush through it?The Blue/White Flow Meter indicates about 135 GPM on the Schedule 40 scale.
However, this is highly susceptible to debris interfering with accurate operation.
The Blue/White Flow Meter has a tube that should be in the center of the pipe.
So our pump is capable of 262 gpm!!!
Yeah..... I'm getting the feeling that the company that did this installation are a bunch of bone heads. First, they install the wrong flow meter for our Sch 40 pipe and then to check the low flow reading on the FV-3 flow meter, they install the BW flow meter incorrectly. Geeez!The BW is also installed right in front of the check valve which you are not supposed to do:
Ahhh... sorry... I will check that gauge and post a photo of it.With almost no head loss which is not possible with that plumbing.
I did not see this gauge which is the pump suction:
How do you determine head loss? I know it's probably a complicated calculation, but given our plumbing configuration what flow rate is our pump capable of? Any way to determine that from the pics or is it more complicated than that?With almost no head loss which is not possible with that plumbing.
Got it. I will get those...Actually, I don't think you posted either of these gauge readings which are the two necessary to assess flow rate:
Is the plumbing on both the suction and discharge side of the pump 3 inch?
I see smaller pipe and bushings so not all of it is 3". Measure the OD of each pipe and they will not be the same.View attachment 607082
Yes.... all pipe but what you see in this picture is 3" pipe. We had a section (about 8') of 2" pipe on the discharge side that was replaced just yesterday with 3" pipe to see if that would increase the flow rate. No luck there.
Hee are the photos of those 2 gauges. So.... anything unusual here? Are these the two pressure readings that determine head loss? If so, is it right around 80 feet of head loss? That would mean our pump is capable of 180 gpm, as JamesW indicated, right?Actually, I don't think you posted either of these gauge readings which are the two necessary to assess flow rate:
So the pump should be able to deliver that 170 gpm flow rate, right? I'm very interested to see what the readings are when we apply the new label to the FV-3 flow meter!Total head loss is about 81' of head which should deliver a flow rate of around 180 GPM. But gauges like that are typically +- 3% of full scale.
The engineering specs for our installation say it is to be installed "between the pump and the filter". Is this wrong? The pool company has to follow the engineering specs, though, right? Should we install another flow meter after the filter, as well? If the specs call for a flowmeter "between the pump and filter" that is the one the inspectors are going to read, right?The flowmeter needs to be After the filter to avoid debris clogging the meter.
