On my parents pool they have a Pentair VS pump that is programmed to run at predetermined times as programmed thru the pump software. I want to install a salt water generator and in my way of thinking it should be wired to the pump so that it shuts off and on with the pump. If it was wired to a timer you could possibly have the pump off (due to the on board programming) and the saltwater generator on. Syncing the timer with the pump programming just sounds like a recipe for disaster. Every power outage would require a re-sync. I have not seen anything online about attaching the SWG to the pump? Am I missing something?
