Decoy205
I sure did last time, and it was like living in the Sahara for 2 weeks. Except it was concrete dust and not sand blowing.People underestimate how messy stone work and construction can be.
He needs these
That is the image I had in my head while you’re showing him the pics.![]()
He had NO idea who he was trying to BullHe refused to believe it, so I scrolled through the pics.
Well played! That way you KNOW it is as right as it could be.Yeah man. Let's work together and get it right.
REALLY??? UNreal!He took 4 chunks of cement with him. Yall's do the math as to if I was the only one he had today.
He should have. It was the same guy who had to come fix the liner tracks cutting through the liner and then liner lock the whole thing for being loose. But thanks.He had NO idea who he was trying to Bull
My 3 ft sheetrock square wasn't long enough to I taped a string to the edge and used the string off the square and the two brackets were off by 2 inches instead of the 4 they looked by eye. Then I marked both centers and the pool center and the 3 didn't line up that way either. So we threw the board on and it looked fine. Maybe it's an inch off and I'll never see it. The other one had the board touching the bendy part on the left side and lots of horizontal pipe coming out the other side.That way you KNOW it is as right as it could be.
They DID. They sure used the level getting the other 2 level with each other, just not level by themselves or square. They scratched the SNOT out of them and all these stands / ladders went to crud with the shortages. The ones without damage to the finish rust in no time, I wasn't taking these. Each one of these marks is from the level being slapped down and they ran across the whole bar. Clearly they had a plenty of tries to get it right. Lol. They also put a few bad gouges/scratches at ground level with the shovel.Did they use new legs?
Just like my stairs that they poured, when I wasn't getting that kind of stairs......... if they did it right, they wouldn't be taking cement home with them. The back of his truck had alot more than just mine in it.REALLY??? UNreal!
Just remember regardless of what the electrician says tomorow when he’s done, you CANNOT bond a pool with the new fangled wireless WIFI bonding technology. Just sayin lolHe needs these
Tomorrow is the electrician to bond the stands. And they haven't had a crack at this yet so then they get their 2 or 3 turns. *Sigh*
and there is the problemHe should have. It was the same guy
and they thought it was good enough..................Maybe it's an inch off and I'll never see it. The other one had the board touching the bendy part on the left side and lots of horizontal pipe coming out the other side.
I was trying to see if I could figure out how many different jobs that came from. Too many that is for sure!! At least they took it with them this time!if they did it right, they wouldn't be taking cement home with them. The back of his truck had alot more than just mine in it.
I got in the pool the first time and saw the skimmer unlevel.
No telling what other mess ups it came from, or how many. But. It's more than just mine. They don't mix/pour cement only to take it back, unless they fouled up.I was trying to see if I could figure out how many different jobs that came from. Too many that is for sure!! At least they took it with them this time!
You know that you're dealing with a real professional when they tap the clipboard.He tapped the clipboard and everything.
100% agree. Except he was *thisclose* to having an early lunch when he did it. A little dry, but high in fiber.........You know that you're dealing with a real professional when they tap the clipboard
