Why are the two valves not able to switch when toggling through pool/spa? Does it need to be a dual body system? Or can a single body system be able to operate those two inputs?
I just had a new pentair system installed & connected to existing pentair actuators. The actuators are connected and move when the toggle switch is flipped over. When the "self test" diagnostic on the Easytouch panel is run, each actuator moves as it should during the test, and the display reads...
