Yes it is.
I also have a 100,000BTU heater for my Intex (18 x 9 x 52) and I am able to raise the pool's temp by ~3deg Fahrenheit an hour (when used with a blanket at the same time).
I also use my heater with a propane tank, a 20 lb tank to be exact. It lasts for ~4 hours. the math is also simple : a 100K BTU heater will consume ~1 gallon of gas in an hour, a 20LB tank has around 4.72 gallons of gas inside.
So basically for my pool a 20lb tank (19$ refill at home depot) can raise the pool temp by ~10deg Fahrenheit, usually in my case is to raise the water temp from 80 to 90 (it takes 4 hours)
One important thing you should consider, a small propane tank will freeze quickly with this heater, after 20 min of use or so, when it freezes your heater will shut itself down.
So you have two choices here, either go with a bigger tank (recommended) or every time you start your heater put your tank in warm water, this will prevent it from freezing.
Enjoy.
