- Jul 16, 2012
- 7,279
- Plaster
- Hayward Aqua Rite (T-15)
I think you’ve found your solution, but since I came up I with my idea before I read the post where you were happy with your idea, I‘ll share it anyway. The idea is for a two-post pergola, with about a 2’ wide section at the top, and about 10-12’ wide parallel to the side of the tub. That’s mostly just to make the structure look aesthetically pleasing, but the point would be to mount a Coolaro shade from the structure that you lower when needed and retract when you don’t. I always like to try at attach function to form if possible. Meaning it looks great and also happens to do the job. And as a bonus, if you build it several feet away from the tub, you can use it to mount a hammock in between the posts. A two-fer.
