Hello,
We had our pool resurfaced a couple of weeks ago. It was done in a standard marcite finish. Due to some issues, we had to fill with both well and ground water (which was surprisingly clear). The guy started up the water with Jacks Magenta and Blue stuff, some additive to my sand filter, calcium, and eventually chlorine and CYA. The water is balanced (although I was instructed to keep PH at 6.8 for now) and crystal clear. However, there is that green statue of liberty tint to it still, which from reading around the forum is probably iron or metals of some sort. I am looking for advice on getting the water back to blue as it was previously in the old pool. I've included some current pictures along with some construction pictures in case anyone notices anything weird in general. I think I may have some staining but I'm not sure what constitutes staining. The bottom couple inches of the sides look slightly discolored along with some spots on the bottom although it isn't blatantly obvious. Maybe it's normal. Appreciate any feedback and tips on the green water and what you see in the pictures. Thanks guys. The first and last pictures are the most current.
