- Jul 3, 2024
- 18
- Plaster
- Pentair Intellichlor IC-40
New user here. Not sure how to start my own post. I think I may have early stages of white water mold. Can someone help?
See aboveI’ve fought wwm myself
Can you share some pics or tell us more about your situation?
Maybe start with a full set or Chem test results and why you think you have wwm
Ahhsome worked very well for clearing pipes. Your bout may not be as serious or require it. Cost me about $30 . Worth it imoAnything in the pipes/filter should generally be taken care of via the SLAM,
As mentioned above, less liquid chlorine is required to slam with the lower cya. Maybe hold off on raising it until after you’ve passed all slam criteriaCYA: 40 ( still need to get higher, trying for 70)
SLAM process seems to be working for me. Twice now,I was planning on starting the process this weekend though finding conflicting opinions on the FC level. Some are advocating for up to 30ppm. Is there added value for going to this level?
White Water Mold: How To Get Rid Of White Mold | Pool Marvel
White water mold is a naturally occurring fungus typically found in pool areas with poor circulation, but not harmful to humans.poolmarvel.com![]()
How to Get Rid of White Water Mold and Pink Slime in a Pool
Pink, white and blue isn't a good look for your pool. Kick the white water mold and pink slime out to avoid illness and keep your pool swimmable.www.swimuniversity.com
Andrew
How do you recommend cleaning the bottom? I don't own scuba equipment. haha. auto cover with flush vault/basin/pit.You need to clean the cover (both sides) - if its an automatic cover also check/scrub the pit.
If it is a solar cover & the bubbles are starting to pop its time to replace
If it touches the water the contact with the slam fc level water for a day may be enough. As you open the cover afterwards & it rolls up the chlorinated water will also end up in the chamber and should take care of it.How do you recommend cleaning the bottom? I don't own scuba equipment. haha. auto cover with flush vault/basin/pit.
