I made the rookie mistake of not turning down the salt cell chlorinator percentage (set at 25%) after putting a solar pool cover over the pool. The cover actually only covers about 75% of the pool, and the chlorine level was way low when I put it on, so I figured "how much of a difference can a cover make?". Well, a lot! The chlorine dipstick was a deep purple when I checked it a few days later. I turned the chlorinator off and removed the cover and 12 hours later I took a sample to the local pool supply company and had them re-check it. They said the chlorine level was still reading higher than their reader goes. They thought the chlorine was probably 10ppm. We have a 22,000 gallon pool. I added 48 ounces of "Pool Style Chlorine Eliminator" and 30 minutes later the dipstick still shows a high chlorine level.
Does anyone know how long it should take for the chlorine eliminator to work? Wondering if I should go ahead and add more chlorine eliminator, or just give it more time.
Thanks!
Thanks!
