Thanks for your feed back. I am willing to create another version if you can give me feed back on a better design. I can typically get a prototype
within 2 weeks and a production version within a month. If you used the silicone adapter I definitely want feedback.
They are. It will work on a flat pool wall surface quite well. Do be ware the lights are about 6" in diameter so much bigger than the Globrite. And they also put out a lot more light.
Moved from here.
Hi @flaled, @mknauss,
Thanks for your feedback and suggestions regarding the Pentair GloBrite situation.
I'm considering to change the Pentair GloBrite lights for the Pool Tone lights from Florida Sunseeker.
Please, may I have your feedback regarding the wall surface taking in consideration the attached pictures?
Please, be aware there is one light (IMG_9854.jpg) installed near an edge in the wall. How could be mount the pool tone light?
Thanks
