I've had my house for about 2 years, and started using TFP this year. What a game changer!
I have a problem with my pump losing prime. I've suspected a suction side leak for some time underneath a mid-sized spruce tree near the skimmer (intermittent sucking/gurgling sounds), but no real problems... until yesterday. I'm hoping there's a new leak somewhere at the equipment pad, and not an immediate need for tree removal and excavation...
If I fill my pump basket with the hose, close it, and run the pump, I see bubbles coming from my drain and one of my 3 returns, but none in the pump basket, then within 15-20 mins, the pump loses prime.
I know I'll need to check my rings/gaskets, but when I started thinking about how to isolate the various parts of the system to locate the leak, I realized I didn't understand it. See photo.
The 3 suction side valve handles have labelling on them indicating they are for the skimmer, vacuum line, and drain, but I don't understand (1) Where the vertical pipe in the ground is coming from, (2) why the drain line is connected to the suction and pressure side of the system, and (3) why there are 2 lines on the pressure side.
I found a "cheat sheet" left by the previous owners (see photo), and it seems to indicate that this plumbing might allow for the drain to act as both suction and return, so that heated water can be sent to the bottom of the pool. "Heat" is only supposed to be open when "Pool" is off, and v.v., and never both closed at once... There is no labelling on the 2 return lines, but I suspect that is what they meant by "Heat" and "Pool". I've yet to ever open my drain cover
... Should I expect to find 2 openings beneath the cover, or are those lines more likely to merge somewhere underground? Or am I completely off the mark here, and something else is going on?
