All,
Found this forum online yesterday and registered. This is my first post!
We have a 1991 Anthony inground Gunnite free form pool in our newly inherited "fixer upper" home. In short, the back yard is a disaster right now. The garden areas are completely overgrown, the yard is mostly weeds, and the entire back yard, and therefore also the pool itself, is surrounded by no less than 20 mature trees (I counted yesterday). The shed roof needs to be replaced as it is rotting. I will snap some pics soon and post up here to give firsthand views and get some reno ideas from everyone here on the forum. I've got my own ideas already of course.
Best I can tell, the plaster surface is original, and is about done. I drained the pool completely over this past weekend, which was full of rotting leaves since the pool wasn't properly covered over this past winter season, and powerwashed the entire surface at 3000 PSI. Even after a thorough powerwashing, the surface is still stained and looking pretty bad. I looked into various paint options (rubber, epoxy, acrylic, etc.) but most of them seem like bandaids that only last a few years at most. The only "real fix" is to have the surface sandblasted and re-plastered right? Given the plaster surface is 26 years old, it's time. I'm already refilling the pool, as I ran water tests on the putrid water and TDS came back really high, so I had to replace the water either way - and I didn't want to leave it drained for a long period of time and risk hydrostatic pressure problems. In hindsight I probably should have at least tried to bleach the surface before refilling it after reading some additional posts on this forum yesterday, but we want to at least use the pool for the remaining season and then start our reno project in the fall if possible.
The house has a three season sunroom off the back (about 15 x 20), and the yard drops down about three feet vertically via a small hill right after the sunroom down to an extended cement pool deck. The sunroom is built using a total of seven sliding glass doors, three of which face out toward the pool area. The drop down right off those three sliding glass doors is currently an overgrown heap of weeds/garden area that extends down and out about six feet - and is blocked in by some older paver style stonework that raises the garden area about 12 inches, which then terminates at the beginning of the extended cement pool deck. On the two sides of the sunroom are garden areas, so of the seven sliding glass doors, only ONE is actually in use (and therefore probably needs to be replaced due to wear and tear). Call me crazy, and yes I know the sliding glass doors were used to maximize viewing area, but the fact that no one can actually use six of the doors for anything other than ventilation, doesn't make any sense to me (I'm an engineer by training that works in IT nowadays). I want the doors to be useful for something other than ventilation after the reno.
So, long story short, we have big back yard reno plans per our list below:
Pool - NEED:
Re-surfacing
Re-tiling
Re-coping
Equipment replacement (want to move to a maintenance free type setup)
Safety cover installation (for off season)
Pool- WANT:
Concrete deck replacement or deck overlay with stonework/pavers (TBD)
Add pool water features:
Integrated spa
Grotto/waterfall feature
Tanning deck
Integrated LED Lighting
Hardscaping/decking:
Raised hardscape between sunroom to near side pool (level with integrated spa/water features)
Wrap hardscape around both sides of sunroom - replace garden areas with hardscaping
Possible outdoor kitchen area (left side of sunroom)
Possible outdoor fireplace and/or firepit area with seating (right side of the sunroom)
Yard plans:
Replace all fencing around back yard (aged wood fencing has reached end of life)
Replace shed roof (or the shed altogether)
Clear out all brush from under trees and landscape cleared areas with stone/mulch
Consider removing some trees
Install gazebo under trees for adjacent seating area for pool
Install hammock between trees adjacent to gazebo
Budget: ~50k (can include DIY efforts to minimize labor costs)
I have a few logistics questions on some of the water features. Do the water features need to have direct access to the existing pool plumbing, or can they be run independent of the existing plumbing? I ask because currently the pool equipment, including electrical, skimmer (only one), pump/filter, and feed/etc., is all located on the far side of the pool, hidden by some privacy fencing.
Since the back yard drops down about three feet, I wondered if I could add the integrated spa on the near side of the pool, built on top of the existing pool deck, remove the current garden area that exists right in front of the three sliding glass doors, and then build up that three feet using dirt/gravel base, and install hardscaping right up to the integrated spa and the pool. I already see a few problems with this design approach - building up the area between the sunroom and pool will block the view of the pool at least partially since we could no longer "look down" into the pool area from the sunroom like we can now. If the spa has to be located near the existing pool plumbing, this design idea won't be possible either.
I will snap some pics when I get home today as raw "before" pics for the record. I will be cleaning up a lot of the landscaping issues over the next few weekends while we use the pool as well, just to get the overgrown areas under control. We may start the fence replacement project during the latter half of the summer as well using vinyl fencing (vinyl is final right?). More to come soon!
Pool - NEED:
Re-surfacing
Re-tiling
Re-coping
Pool- WANT:
Integrated spa
Tanning deck
Yard plans:
