Hello! Looking for some help regarding expected PSI changes under a manifold.
We are building a new pool and in the plumbing stage. The plumbing is all in place (connected to filter/pump) and we passed the city inspection. One thing to note that prior to the inspection, we had a leak at the filter gauge that the PB came back to fix and after re-pressurizing, we found another leak in the O ring of the pump. On the third try, the PB pressurized right before the inspector came over and passed holding at 30 PSI for 10 mins. I had some concerns as I noticed the pressure had dropped from 30 to 26 overnight (3:00 PM, measured again 7:22 AM next day). I brought this up to the PB and he said this was expected as there is areas in the equipment that will naturally lose pressure (eg O ring, connections). Is this true? If so, how much can you expect to lose through the equipment?
I was not comfortable with the PB explanation and was afraid there was slow leak somewhere. The PB disconnected the pipes from equipment and created a manifold and pressurized to 32 PSI (11:11 AM). The PB said the pressure should remain the same with small changes expected from the skimmer (1-2 PSI) since the connection is threaded. Over the last 2 days, I noticed the PSI to change (table below)
Question to TBF folks (thank you!!): what PSI loss can I expect under a manifold? We are located in Southern California where the temperature is moderate (high 85, low 65). How much PSI loss is expected through the skimmer? Also through equipment?
SAT 7/9/22 | 12:47 | 32 |
SAT 7/9/22 | 17:58 | 32 |
SAT 7/9/22 | 22:30 | 30.5 |
SUN 7/10/22 | 8:24 | 29 |
SUN 7/10/22 | 10:13 | 29 |
SUN 7/10/22 | 14:59 | 29.5 |
SUN 7/10/22 | 21:24 | 29 |
MON 7/11/22 | 7:53 | 27 |
