Anyone know exactly how the timer on the intex sand filter works? If I set it on 4, does it run for 4 hours, then stop, and then turn on after 4 hours again and continue in that pattern?
dccordell said:If it operates in the same manner as the Intex 635t Cartridge pump, it will run for 4 hours, then off until about the same time the next day, then run for 4 hours again, and so on.
4 hours each day, starting about the same time each day as you started it the first day.
wozzukes said:The pump timer is a pain. It will come on again approximately 24 hours after you turn it on by switching it to the timer. So if you turn it on using the timer at 8am and it runs for 4 hours and then you vacuum later that night, say 6pm by switching it on and then turn it back to the timer when you are finished, it will run for the amount of time it was set at that time and then come on again approximately 24 hours after that time, or around 6pm the next day. I contemplated connecting it to an external timer (actually a z-wave device) and leaving it always on and letting the timer run it, but I have had issues with the GFI on the pump tripping if our power goes out. So because of that, every time the external timer would shut the pump off then the GFI would trip and it won't come back on. I have been contemplating cutting of the GFI on the cord and just using the timer plugged in to a GFI outlet, but the timer I have won't fit with the box that the GFI outlet is in so I would need to do some rewiring (in which I would put a dedicated circuit to it). We just bought a vacant lot and are going to be building a new house so I don't really want to spend any time/money doing anything now when I will have a new house that we are going to have wired with the pool in mind, so I'm just dealing with the annoying timer for this summer and set a reminder on my phone to turn the pump back to the timer so I don't forget whenever I vacuum. Next summer will hopefully be fully automated, if I get my way![]()
BlueCorn said:Believe it or not, in most areas of the US, that behavior of the GFCI is per the electrical code. Non-hardwired GFCI devices must trip when power is interupted. I installed a GFCI outlet for our pool so I intend to remove the Intex one as well.
MattE71 said:BlueCorn said:Believe it or not, in most areas of the US, that behavior of the GFCI is per the electrical code. Non-hardwired GFCI devices must trip when power is interupted. I installed a GFCI outlet for our pool so I intend to remove the Intex one as well.
I think you can have your GFCI in your breaker panel already and not at your outlet? That's what I have been told anyway. Here in Canada anyway!
