Inground vinyl liner install
Rakuz66
7
SE Pennsylvania
I went around my “Under Construction” vinyl liner install today with my 4ft level, I found 1 wall panel where it leaned in about a 1/2 inch,,, is that too much? Any type of hazard ?? They will be poring the concrete to secure the braces on Monday, thx
No turnbuckle supports, it’s a polymer wall pool with brace supports. I basically fixed the lean myself. However in doing so I seen this! These braces are supposed to catch the end of one panel and the beginning of another. Obviously, this is only catching 1 panel, and there’s a shim in between the panels on a curved section. There are 3 braces in a row like this. It’s in the shallow end of a kidney pool. Do I shut this down now? Or is this normal?
I noticed this tiny stress fracture in the back of my polymer pool panel today,, is this a big problem? What type of epoxy can I use on polymer panels? thanks
What model pool are we discussing?
Have you asked the pool manufacturer?
I don’t think epoxy or any glue will structurally strengthen a crack in a panel.
