Next week I'm having Jandy IQ904PS (Aqualink RS PS4 Pool-Spa Kit) automation system installed by a local pool pro. Currently I'm using the basic iQPUMP01 controller which allows me to control and schedule speeds for my main filter pump (only), so this will be a nice upgrade.
I've been familiarizing myself with the Aqualink RS system in anticipation of the install, but there's one thing I do now with my iQPUMP01 controller that I can't figure out how I will do with the full Aquilink RS system. I'm hoping someone here can tell me how.
I run my filter pump 24/7 and the schedule looks something like this:
9PM - 10AM : 1750 RPM - low flow just to keep pump primed (equipment is uphill of pool/spa)
10AM - 1PM : 2200 RPM - booster pump runs here
1PM - 9PM : 2000 RPM - baseline daytime operation
I usually make my muriatic acid additions in the morning between 7-8AM, and at this time the pump is still running slow (1750 RPM) as per above schedule, so when I add the acid by slowly pouring in front of a return jet, I like to temporarily kick up the pump speed to 2400 RPM for 15 minutes to help disperse the acid. Using the iAquaLink mobile app with my iQPUMP01 controller, there is a "custom speed" option which makes this possible:
Selecting this function runs the pump at 2400 RPM for 15 minutes and then automatically returns to the normal schedule.
How do I do this in the full Aqualink RS system? I'm assuming there must be a way, something like "Quick Clean" button found on pumps, but for shorter time periods (15-30 minutes). It doesn't need to be infinitely adjustable like the option I show above, if I could set an "on-demand" routine (2400 RPM for 15 minutes) and assign that to a button in the App, that would be OK too.
Thanks for help.
Thanks for help.
