I just watched the guy on the counter put the pump back together. I had taken the old motor off to bench test it because I could smell it running hot. It ran ok, but then I put the shaft seal on backwards and melted the parts. I took the pump (sans motor) to PAP and had them rebuild the pump. Bolted the old motor on and it ran hot for a couple of days then started tripping the thermal overload. I ordered a replacement motor and put it on the newly rebuilt pump. That's when I started checking amps. I'll bet the old motor was running high amps, too, I just never checked it under load. Anyway, when I open the suction valve(s) all the way the pump runs quieter with no cavitation, but as we now know, draws too much water and overworks. To keep the amps down I throttle down the suction and have to listen to that cavitation-like sound. I'd much rather just have a nice humm, so I will change out the impeller.
To answer your questions, I'd have to find my receipt to see exaclty what parts I had installed.
