Just had our pool redone. We have a variable intelliflo pump controlled via i-aqualink.
When I used the hot tub, everything works fine but, the pump goes up to 3450 rpms and the heater comes on.
Now, when I try to use the heater for the pool, the heater does not come on and the message on it says "check flow".
My understanding it has to do with the rpms on the pump. I changed them in the settings to 2,800 and even though the status shows the pump is working faster, it's not really putting out 2,800 rpms. I then went ahead and just set them to 3,450, and the same thing, the pump does not go to the target rpms even though it shows in the app that it is. I can hear it. Also, when the filter is just starting, I can hear the pump working much faster than the supposedly 2,800 rpms that I set for the heater mode. The priming speed is 2,500 rpms.
Any ideas? I am getting someone out to take a look next week but was hoping to get this resolved earlier.
Thank you!
Thank you!
