- Jun 26, 2017
- 249
- Plaster
- CircuPool Edge-40
I don't have enough gray matter to help you.... but I do have enough to know- Your paradise is beautiful.
Unfortunately, it does not. It's just a simple valve with electronic spark ignitor.If your firepit has an option to flip a switch to start it, then you can add that to your automation to control it. Simply wire the fireplace switch into a relay and let the automation control the relay. Jandy automation has a dusk to dawn timer but I really don't think I'd set up a fireplace on a regular timer.
Agree.I suspect part of the cost is to cover potential lawsuits. Seriously. People lighting the thing when there are kids in it, or the family dog, or a pool float.
In my case, "they" is me.The one thing I am confused about is if you paid for a firepit, why didn't it come with the on/off mechanism? Your pool looks quite expensive I can't imagine they left this out.
The one that is controlled with a remote can be controlled by Alexa or Google along with any RF ceiling fans or any other RF device with one of these. I use this for all the ceiling fans in my house.I have 2 gas fireplaces in my house and the gas supply to both of them is always on. They both have gas cutoffs like you show, but I rarely use those. Sometimes in the summer when I know I will not be using it anymore and turn off the pilot light. Both of my fireplaces are automatic with pilot lights. One is battery with a remote and one electric with a wall switch. Both will automatically turn off the gas supply if the pilot light goes out (thermocoupler). I doubt that gas switch you show is designed to be turned on/off for lighting the fireplace. I suspect you have a pilot light somewhere or an automatic pilot light. I am fairly certain all modern gas fireplaces have a thermocoupler like I describe above to shut off gas flow when no flame is detected.
