- Jul 20, 2017
- 254
- Plaster
- Pentair Intellichlor IC-60
+++Scroll to bottom for latest updates+++
Hi All - Pool company opened my new pool (opened for a month in 2022) three weeks ago and I finally had a chance to use my new TF-Pro Salt with Smart Stir testing kit. Some grey matter on the bottom of the pool, which I assume could be dead algae? Pool company opened the pool three weeks ago with 2-3 gallons of liquid chlorine and a bottle of algaecide. Since then, we've had four (4) chlorine pucks (two (2) in each skimmer) since the pool is only 60F so SWG is not running. However, planning to start heating the pool Friday.
Water is clear and VSF pool pump running @ 2300 rpm from 8am - 8pm. Intellichlor at 50%, but not much happening here with the cooler pool temp. My numbers are kind of all over the place. FC seems okay, but the others are outside the recommended rangers per Pool Math.
Pool Math recommends adding below. Can I add everything at once? Is the 91lbs correct? With the amounts reflected below I'm looking at hundreds of dollars of chemicals
FC - 4.5
CC - 0
TA - 130
CYA - 40
pH - 8.2
CH - 100
Salt - 2550
- 4lbs of Dry Acid (lower PH and also should remediate TA)
- 91lbs of Calcium Chloride (raise CH)
- 8lbs of Dry Stabilizer (raise CYA)
FC - 4.5
CC - 0
TA - 130
CYA - 40
pH - 8.2
CH - 100
Salt - 2550
