13.4 volts x 3.91 amps = 52.4 watts, so the numbers seem off.
I would expect the voltage to be double or about 26.8 VDC for most SWGs.
My Intellichlor 40 lists the minimum flow rate as 25 GPM in the manual which is no different than this new series of SWG.
No….Pentair likes you to be in the special super secret club to get info. You need to be authorized by 76.9 layers of beauracracy and know the secret handshake to get information. Don’t get me started on their required authorizations to perform warranty work on their equipment that’s broke when delivered.QR code goes here.
IntelliChlor® Plus & LT Salt Chlorine Generators
The IntelliChlor® Plus & LT Salt Chlorine Generators are new and improved designs that use ordinary table salt to help make pools cleaner, clearer, and silkier.www.pentair.com
Seems like they do not want to make it easy for customers to find information.
Ha, ha, that was my first [cynical] thought, too! Along those lines:I thought "how nice of Pentair to include the lifecycle reduction tool in the kit"
--Jeff
It’s definitely been redesigned…better is tbd….heres an excerpt from one the the PowerPoint presentations regarding the sensor redesign. I’ll keep digging for more detailed info.Ha, ha, that was my first [cynical] thought, too! Along those lines:
It speaks volumes about Pentair "engineers" that it took them all these years to finally figure out the LED should be labeled "Chlorinating" instead of "Cell." It feels like one of them finally got a pool!!
But hey, we'll take what we can get. This is a significant upgrade from my IC40, so credit where credit is due. And they chose to make these drop in replacements, they could have easily gone another way. Great job Pentair, and thank you so much @Skenn81 for this awesome review.
I have the dreaded "zero salt" problem with my latest IC40, though it's still generating. Same failure my first one had. Time will tell if this upgrade is just "prettier," or if it addresses some of the other problems the IC has had, especially that awful flow switch/salt reader combo. [Back to cynical mode!]
That sounds fantastic!It’s definitely been redesigned…better is tbd….heres an excerpt from one the the PowerPoint presentations regarding the sensor redesign. I’ll keep digging for more detailed info.
I wonder how much a replacement sensor mode will cost when one of the three sensors fails.It’s definitely been redesigned…better is tbd….heres an excerpt from one the the PowerPoint presentations regarding the sensor redesign. I’ll keep digging for more detailed info.
Do we have preferred dealers here? Ill probably grab one next season.
