Found some algae in the hydrostatic valve drain. Have tried everything but no way to remove cover, have broken some of it. Used toothbrush to try brush some out, not many options
Due to not being able to get the cover off, made a makeshift vacuum out of pool hose, funnel and hosepipe (which could fit through the broken parts i made in cover) and along with toothbrush and screwdriver managed to clean the inside of the drain. Now it looks very clean (after 2 hours diving up and down) but I guess I will not know if I got 100% of everything, definitely can't see anything significantly left in drain (no green). Then dove down with tube and dropped some liquid chlorine directly into drain.
Hoping all this effort shows some improvement in the results. Did 1 hour cleaning at lunch (ended at 2pm) and a second hour later after 4pm but between 2pm and 5pm did not get a big drop in FC, not sure its related to my cleaning of less sun on the pool. Actually probably not related as disturbing it should have used more chlorine and only did vacuuming at 4pm.
Can this small amount of algae cause the OCLT to drop by 2ppm?
Thanks for all the patience and help so far.
