Calcium Chloride not getting hot
When calcium chloride hexahydrate dissolves in water, the process is endothermic, meaning it absorbs heat from the surroundings.
Calcium chloride hexahydrate absorbs 31 btu/lb.
31/21 = Temp drop of 1.5 degrees for 1 lb in 2.5 gallons of water.
Calcium chloride tetrahydrate is only slightly exothermic (25 btu/lb).
25/21 = 1.2 degrees temp increase for 1 lb in 2.5 gallons of water.
It's possible that if there really was very little or no temperature rise, the calcium might have been one of these compounds or maybe something else.
The people who answer questions are volunteers.
If you find the site to be a good resource, please consider making a donation to help support the site.
Thanks.
Y = 0.0431X^2 + 0.3754X -157.3591
Y = Btu/lb.
X= Percentage CaCl2.
________________________________________________
For 1 lb CaCl2 added to 2.5 gallons of water:
Y = 20.85Z
Z= Temp rise.
Btu released = (20.85 lb)(Degrees F of Temp rise).
20.85Z = 0.0431X^2 + 0.3754X -157.3591.
Z = 0.00206715X^2 + 0.0180048X - 7.54719904
For example, if the temp rise is 12 degrees then the percentage is 92.98% for CaCl2.
If the temp rise is 0 degrees then the percentage is 56.23% for CaCl2.
If the temp drops by 1.48 degrees, that puts the percentage at about 50% CaCl2.
Calcium Chloride anhydrous gives 317.2 Btu/lb. when dissolved in water.
Solubility in water = 74.5 g/100ml at 20°C.
Adding 1 lb anhydrous CaCl2 to less than 0.3 gallons of water will result in the water boiling (Water temp = 84 degrees before adding CaCl2.)
Y = Temperature Rise.
X = Gallons of water.
For 1 lb CaCl2.
Gallons.....Temperature rise (F).
0.12...............317.2
0.161...............236.4 (Maximum Solubility is 1 lb in 1.34 lbs of water).
0.24...............158.6.
0.30...............128 (128 + 84 = 212).
0.48.................79.3
1.0...................38
1.5...................25
2.0...................19
2.5...................15.2
3.0...................12.67
