PB said it would be about 10,000 gallon pool and 600 gallon hot tub. So should I get IC20 or IC40?
Please make sure to give the first guy a second chance after you have learned some things. It is only fair to him. I do this with any bidding I do for work.I’m not sure if I will be using this guy, but now I know a lot more to look at with the next few guys.
Hud,I’m not sure if I will be using this guy, but now I know a lot more to look at with the next few guys.
Hud,I appreciate all the advice, I actually have 4 more (thursday, friday, monday and tuesday) and am pretty sure I can eliminate two due to poor reviews. I scheduled those, one halfway mistakenly thru a facebook ad and one before I really knew anything and later saw a number of bad reviews. The final two were referred to me from people in the area (all anyone does here is gunite), so I feel pretty comfortable with both of them; however, one said he was too busy to start right away, and it would be closer to the end of summer before he could begin (small builder, only likes to do a couple at a time). May cancel the other two just so I don't waste anyone's time.
@jimmythegreek they have quoted a 700 SF Hayward cartridge filter, I'm assuming this would be considered oversized right? (its only 10,000 gallon pool)
Hud,I think the property line is actually 6" past the fence so that will give us a little more room.
Also, if your property line is 6' past the fence, I would consider moving the fence back if setbacks permit it. This would be a small cost to gain considerable real estate for the pool.
Are you locked on the design? Asking only as 3’ is a tight space between the house and pool. I would consider shifting tothe rear wall if you can to give a little more room for the house side. You likely have a rear setback to factor in.
