- May 18, 2023
- 77
- Plaster
- CircuPool RJ-45
Have an RJ45+ on the way. Currently have a VS950 pump. I’m debating on installing a timer vs just running the pump 24/7. Due to the pvc pipe length limitation, I am going to have to install the flow switch after the cell so I can include the cell length as straight pipe per the owners manual on the RJ. I currently run 830AM to 5PM around 1300rpm. I do tend to get an air pocket in the pump basket at lower speeds that develops over a day and is about an inch deep. I haven’t found any leaks, o-rings are lubed, just assuming because I’m oversized for my pool? Anyways, I think I am leaning towards running 24/7 and I’d like to go as low as possible. Would the air pocket be a concern? I don’t want to have to run my pump at higher speeds and increase my electric bill. Should I just run a timer to avoid this issue and run at higher speeds for a shorter time?
