hello friends!
Our AquaPure 1400 SWG was just installed. I was not home when the installer put it in and the gentleman who came by today to check it did not have answers to several of my questions. I may have completely misunderstood the recommendations for which SWG to get but I thought this SWG would connect to my Jandy AquaLink PDA (PDA-PS4 Combo, firmware 7.1, jbox 5.4, handheld 5.5), but it doesn’t. The installer put a whole new box on the pool equipment pad (AquaLink RS Power Center). So my questions are:
1. Do I need some kind of wire that connects the two so that I can check the salinity, etc. with my PDA?
2. If I DO, is it worth doing? If I don’t connect it then how often should I go back and check on the unit to ensure the salt levels and chlorine are adequate?The salt should stay pretty consistent so I’m not having to monitor it all the time, correct?
3. I know I have read on here about the optimal pump run time for SWGs are, but I can’t seem to find it now. I have a variable speed pump and am unsure how long to run it?
thanks for you help, as always.
