Anyone have NSF/ANSI/CAN 50
More specifically, I'm looking for the L1, L2 and L3 water testing accuracy standards from Section O.12.
I HAVE L1, L2 and L3 for pH, FC and CYA...I'd like the rest.
Water quality testing devices accuracy levels Section N-11.12 (formerly Section O.12).
It looks like the section is now N-11.12.
Do you need to know the accuracy of test devices for different chemicals?
I have the devices to the levels. I don't have the tolerance for the levels other than pH, FC and CYA...unless N changed them...Here is O.12 for pH as an example:
Annex O.12 Accuracy Testing: Revised the accuracy level tables for pH, chlorine, and bromine and added new accuracy level tables for hardness, alkalinity, cyanuric acid, total dissolved solids and salinity as follows:
O.12.4 Accuracy levels for Hardness
O.12.5 Accuracy levels for Alkalinity
O.12.6 Accuracy levels for Cyanuric Acid
O.12.7 Accuracy levels for TDS
O.12.8 Accuracy levels for Salinity
N-11.12.1 Accuracy levels for pH (range of operation 5 to 10).
N-11.12.2 Accuracy levels for
N-11.12.3 Accuracy levels for
N-11.12.4 Accuracy levels for Hardness
N-11.12.5 Accuracy levels for Alkalinity
N-11.12.6 Accuracy levels for cyanuric acid (range of operation 0 to 240 mg/L)
N-11.12.7 Accuracy levels for TDS
N-11.12.8 Accuracy levels for Salinity
These companies should have the specifications and they should be able to give you a copy.
Industrial Test Systems, Inc.​
1875 Langston Street​
Rock Hill, SC 29730​
United States​
800-861-9712​
803-329-9712​
LaMotte Company​
802 Washington Avenue​
P.O. Box 329​
Chestertown, MD 21620​
United States​
800-344-3100​
410-778-3100​
Palintest Limited​
Palintest House, Kingsway​
Team Valley, Gateshead​
Tyne and Wear NE11 0NS​
United Kingdom​
720-765-8944​
Pentair Water Pool and Spa, Inc.​
1620 Hawkins Avenue​
Sanford, NC 27330​
United States​
805-523-2400​
Taylor Water Technologies LLC​
31 Loveton Circle​
Sparks, MD 21152​
United States​
410-472-4340​
Zodiac Pool Systems LLC, DBA Fluidra​
2882 Whiptail Loop #100​
Carlsbad, CA 92010​
United States​
760-599-9600​
