I'm in South Florida and need to get a new pump. I looked through the forum to no avail.
I have an old 1 hp pump and it's time to get the variable speed pump. Boy they are expensive.
I was looking at the Eco-Boost 1.5 HP 230-Volt In-Ground Swimming Pool Pump with Variable Speed and LED Control Panel, model 75019
XtremepowerUS Eco-Boost 1.5 HP 230-Volt In-Ground Swimming Pool Pump with Variable Speed and LED Control Panel 75019-H1 - The Home Depot
Can anybody shed some light into this pump? I rather not spend $1000 for a VSP.
It's an old 12,000 gallon pool with the 1 1/4" PVC pipes.
It has just 1 skimmer, 1 drain, 2 returns and 1 vac port for the Hayward Navigator through a C-900 cartridge filter. That's it.
No spa, waterfall, etc.
I had the vacuum line installed some years ago. That's a 2" pipe.
Also, is it ok to go with the 1.5 hp VSP pump to replace a 1hp pump with my 1 1/4" pipes?
Any other information would be greatly appreciated.
