- Jun 24, 2021
- 15,826
- Vinyl
- CircuPool RJ-60 Plus
Use liquid chlorine. Pucks contain CYA and chlorine...no way to control the addition of each, bit of a get what you get. Using liquid chlorine and CYA, you control what is added.
- Cya <30 added 2.5 lbs to the sock so it should be approaching 25. Im gonna run tabs to get it the rest of the way if there is no issue with that.
- CL - .5 ---> 3 with liquid this AM
- I dropped 2 tabs in the floater this morning so it stops going to 0 in between rounds
- Is this Kosher?
Why? 200 is what is recommended on the npc. 250 is just fine. Don't add more.CH - 300 headed to 350
- will mix another 10 lbs or so to get there today
What is your CSI? In pool math, upper right gear, enable track CSI and track Temperature, and at the bottom enable sharing with TFP. Use your TFP login/password. That way we can see your logs.
No idea. @ajw22 @JamesW @onBalanceAlso i noticed this black spot appear about a foot below the tile in one spot
