CYA is 60 FC is hard to read. I stop count at 30 dropsAeration will raise your pH. It will not help burn off chlorine.
What is your FC level and CYA level?
Any FC level up to SLAM FC for your CYA is safe to swim in. See...
The Free Chlorine and Cyanuric Acid Relationship
Managing your cyanuric acid and Free Chlorine levels is key to stabilizing your pool. Learn how these two items affect each other.www.troublefreepool.com
Aeration - Further Reading
Free Chlorine - Further Reading
Just retested the chlorine..With 10ml or 25ml sample?
CYA 60 you are safe to swim up to FC of 24.
It was actually 71 drops at 10ml line. So calculated 35.5ppm (71x.5) whoa!!!W/ a 25ml sample every drop counts as 0.2 fc.
0.2x 30 drops = 6ppm fc
with a cya of 60ppm that is just shy of targetrange & barely above minimum
FC/CYA Levels
If u wish, you can save reagent by using a 10ml sample & every drop counts as 0.5
There are no inbetweens w/ cya (always round up) so anywhere between 70 & 80 counts as 80It was actually 71 drops at 10ml line. So calculated 35.5ppm (71x.5) whoa!!!
CYA is hanging around 75
Long story as to why I added so much chlorine but in a nutt shell …my pool wouldnt clear for nothing and every bit of chlorine I added was getting consumed. I did use floc and that helped me see the bottom and I was able to vacuum the floc twice. The next morning it turned green with only 1ppm of FC! Out of frustration and not clearly thinking I dump a 12gal (10%) of chlorine in.There are no inbetweens w/ cya (always round up) so anywhere between 70 & 80 counts as 80
The corresponding slam level is 31ppm so its not too terribly high & will come down.
Your cya is quite high for a manually chlorinated pool -
How are u chlorinating? Is there a reason you added so much chlorine?
It was out of frustration …kicking myself in the Rear now.Why did you raise it to that level? What is your CYA?
At 80 CYA 30 FC isn’t too far out of line, as mentioned just above.It was out of frustration …kicking myself in the Rear now.
CYA 80
