Cell is dead (green light blinking, no chlorine generation). Cell says it has 40% life left, but this listing should be considered as parts only.” Would it be worth a shot for $100 to buy this one used and get a new cell or just buy a new one and be done with it? |
How many relays are you using in the existing 4 relay controller? Usually there's a spare and you should be able to use that for the swg. Photo's would be helpful.I’m adding an IC60 salt generator, heater bypass and a check valve.
Considering adding the intelliPH controller and if I’m not mistaken..it will require a newer controller as I just have the Pentair VSF pump and an intellicenter 4 station controller that I don’t believe will control the SWCG or PH controller.
I’d prefer to stick with Pentair and if I have to do all of this, I’d like it to be able to connect to WiFi so I can monitor and control while we are away.
Any suggestions as to a good controller to swap over if I need make this swap over.
Thank you,
Donnie
I believe I’m using 2/3 or 3/4 of the available relays currently?How many relays are you using in the existing 4 relay controller? Usually there's a spare and you should be able to use that for the swg. Photo's would be helpful.
Thanks.
Chris
Just ordered. Thank you sirYour picture appears to be a Pentair FNS plus 60 de filter. If that is the case, the Pentair 261152 2 inch threaded multiport valve would be compatible with that filter.
IntelliConnect will not work for you.I was looking at the intelliconnect product last night but I don’t know if it’ll have everything Ill need.
Need main pump, booster pump, heater, SWCG, PH dosing pump and hoping to control lights.
