Good morning all,
SOUTHERN NJ HERE. So I made the mistake of asking on a facebook group and that was more useless than anything, few good points made but other than that is was the people bashing what I want to do
. Have been trying to get quotes for about a month for a May installation and due to their communication and info they provide I really liked Niagra Pools & Spas in Turnersville NJ. The 3 others I contacted either never contacted me back or once they did it was like phone tag to get ahold of them, not something I want to deal with during installation! Pricing from Niagra Pool quote are below, this is semi-in ground approximately 30":
$17,595 -Pool Package: 18' x 33' x 56" Sharkline* Oasis EAW (Extruded Aluminum Wall) pool, Liner, 1.5hp 120v variable speed pump and filter, skimmer, 1 return port, cover, and maintenance/cleaning kit
$1,100 - Salt chlorinator system w/salt
$350 - Wedding cake steps
$200 - Wall foam
$2,900 - Pool Installation
$22,145 total cost for pool
Site Work Quote:
$5,000 - Excavation and haul away of soil in addition to about 5 yards of fill that's in a pile at our property
$3,200 - Backfill of pool using excavated soil: will need to be moved by hand due to space
If your anything like me you probably pooped a bit with the number for site work lol, I will say the guy that came out to do a site visit told me moving dirt is expensive, not bashing them at all, labor aint cheap!! Highly considering doing the site work myself, pool guy told me that isn't an issue with any of their warranties and they will come out to check when it's done for right depth/level. Sunbelt was under $3,000 for a week rental of a 6 ton mini excavator, 7 yard Dump, and ground protection pads. Don't think it will take a week but quote that for worst case. Before anyone says it, I know this is around 70 yards of dirt, I know it's not easy, and as far as operating I dug the foundation for my garage (blue building in the pic) and my patio by myself for the most part, I'm no expert but I can operate, I own a transit and a laser level; just getting all that out there because that's what everyone wanted to comment on with the FB post
With all that being said I had a few questions for additions and backfill
Backfill:
-Sandy soil in my area, good to just use what comes out of the hole for backfill?
-Recommend any barrier between ground and exterior of pool wall?
-Was also thinking pavers OR rubber mulch/river rock/pebbles 24" around pool
Install/Pool Add-ons:
-Liner pad OR Perlite on top of sand base
-Foam coving
-Additional return jet on far wall
-Hard pipe everything (would be extra for pool Co. to do
-Larger pump? is a 1.5hp good enough for 20k gallons?
Anything else that you would recommend is appreciated. We aren't rich but we aren't broke either lol. We are kind of doing the bare minimum for it this year with a small exterior entry step with plans of doing landscaping, lighting, larger entry deck/step, and some other add-ons NEXT season or winter since we are already doing some fencing this year during the install.
Thank you for the help! Site pics are attached, sorry they are crappy I was outside last night marking. And the yard will be spotless prior to starting! Have to move the wood pile and purge some
out to the curb! Also, setbacks are correct and marked on the pics along with the pool shape. Out township requires 6' from p[roperty lines and we have a 20' utility easement on the far side.
$200 - Wall foam
Site Work Quote:
Backfill:
-Foam coving
