Hi all. I run a Hayward Navigator cleaner which is permanently connected to the vacuum plate. But the existing vacuum plate is a Kreepy Crawly Autoskim vacuum plate, and the hose is connected to a Kreepy Crawly Autoskim valve.
The vacuum plate has like an 'air release valve' built in, which presumably prevents the vacuum plate lifting when the pump shuts off (the previous owners kept rocks on top of the skimmer plate because this can still happen). The Autoskim valve is supposed to allow excess vacuum to skim the pool simultaneously, but in my case it works well as a 'suction bypass' when the Navigator gets blocked, which does happen fairly often with long thin leaves I get in there. It appears the Autoclear Chlorinator system I have doesn't shut down the pump when there is no flow, it only sounds an alarm and turns off the chlorinator cell, so the Autoskim valve is allowing flow to continure through the pump.
Buying a Hayward skim plate or similar will remove the 'air release' and 'suction bypass' devices. I don't know if they are required or not or what I need. I'd be concerned when the cleaner blocks that there will be no flow through the pump for long periods. Any advice is appreciated, thanks.
