- Jun 25, 2020
- 75
- Vinyl
- Liquid Chlorine
- Solaxx (Saltron) Reliant / Purechlor R4
TYYour cya shouldn’t really change unless you did something that would change it (exchange water, add cya)
If fc falls below 10ppm check ph, adjust if needed & then carry on with slam but it shows 7.6 at last check when your fc was 16ppm - generally the ph test goes falsely high as fc increases over 10ppm so it’s probably fine.
This is day 6 of SLAM. Not done but looks good compared to initial pond green!
