- Apr 30, 2024
- 5
- Vinyl
- Intex Krystal Clear
I currently have a green pool. I am going to use the SLAM method but I cannot get rid of the 91 error message on my Intex SWG. I have tried cleaning the blades with vinegar and reversing the power cord (basically everything I found suggested on you tube besides messing with the circuit board). After I flipped the cord it worked for about 4 minutes and then stopped again.
Also when I got the water tested at Leslie's, it read that my chlorine level is fine but then my test strips said I have no free chlorine, no CYA or bromine. I am not sure what to think.
So my question is, do I need my salt cell functioning before I address the algae problem by shocking it? Or will the shock fix the SWG problem?? I don't want to waste my time and money by adding all the shock if it is necessary for the generator to be working.
For reference I have an 18 ft Coleman and a sand filter.
Any suggestions would be VERY much appreciated, I am out of my mind with frustration.
Thank you!
Thank you!
