- Jul 21, 2013
- 53,827
- Plaster
- Pentair Intellichlor IC-60
Pressing SPA ON should do something when the ET is asking for heat.I get the red flame when I press SPA on the app, not directly on the heater. Pressing SPA (or Pool) on the heater doesn't do anything as it seems to be getting controlled/overridden by the Easy Touch
I wonder if some buttons on the membrane keypad are bad.
It should be noted for all trying to help that you have an ETI heater and not a MasterTemp.
When you have the red flame and heat on in the APP what happens when you press HEATER OFF?
What happens when you then press SPA ON?
What happens when you press POOL ON?
