I have a problem with entering pH values on the calculator. I can enter whole numbers such as 7 or 8 but cannot enter 7 comma 4 for example because the comma symbol on the keyboard that pops up has the comma symbol grayed out. This seems odd.
This issue has been a thorn for some time now in our side. May I ask what device and what language you’re using?I have a problem with entering pH values on the calculator. I can enter whole numbers such as 7 or 8 but cannot enter 7 comma 4 for example because the comma symbol on the keyboard that pops up has the comma symbol grayed out. This seems odd.
I am using a Samsung android. BTW I have tried using a dot for the pH value, I.e. using a dot instead of a comma but although the dot key is there on the pop up keyboard nothing happens when I tap it. ???This issue has been a thorn for some time now in our side. May I ask what device and what language you’re using?
Thanks. Have tried using a period but although the key is on the pop up keyboard nothing happens when I press it. ???Welcome to TFP! We use a decimal point (period) to specify tenths in the pH, so a comma will not work in the PoolMath APP. If you use a period it should work just fine. Hope that helps.
Not sure. I am using the keyboard that pops up when I enter data on pool mathBy any chance are you using a third party keyboard?
