Omni Logic and Pal lights?
ChrisLPC
In The Industry
Jul 11, 2023
129
Ohio
Almost done wrapping up an install. It says on the Pal light driver that it is compatible with Hayward automation. Just put the dip switches in a certain order and remove the Wi-Fi module and don’t use the remote. I have looked all over Pals website and Haywards with not much else on it. What is the actual functionality if I use the OmniLogic to control the Pal lights? Do I have the electrician wire to a high voltage relay like a normal colorlogic light? Will you still be able to change colors correctly? Or should I just have the electrician wire it like normal and keep the remote for the bubbler lights which are Pal? This is a big install with pool, spa , 320 colorlogic and 320 crystallogic, with lots of other stuff.
