Need help with leaking flexible hose
richierich
752
Long Island, NY
Hi all - I have what I suspect is like a pin drop hole in my flexible hose. Every time I dry it, it gets a little wet again in this one spot. Any idea on what I can use to fill the hole? Maybe silicon? Maybe krazy glue? I don't know. It's like the 10th ridge from the top of the hose return back into the pool. It's not as simple as get a new hose as you can see from the 2nd pic its connected to my SWG that I had someone hook up.
Thank you
Thanks, I'll try that. I've been using these hoses for a few years and never had an issue. Any idea how these pin holes happen? I live in NY and leave them in a shed, perhaps the harsh winters make them a bit brittle? Should I store them indoors you think?
The hose is under pressure. No repair will last for long.
Replace it - it’s gonna fail at some point. Heat, sun, pressure takes a toll. I had one break on me - what a mess.
