I went to open up the pool today, and I'm having some major leaking from the pipes in/out of the heater. I'm guessing something settled and now the connections aren't lining up just right. There's really not much wiggle room on either side. For the pipes to the pool there's very little pipe above ground. For the pipes into the heater they're pushed up against the openings cut in the side of the heater. The junction has o-rings, but they don't protrude much so there's not much compression available to fill the gap. What would the easiest fix for this be?
