Hayward OmniPL, cooldown mode for heater and bypass valve actuation
tommelton
213
Suburb of Atlanta, GA
I just installed a Raypak 400K NG heater, controlled by Hayward OmniPL automation. I installed a Jandy 3 way bypass valve (with Hayward actuator) and a Jandy check valve to prevent any backflow thru the heater. My question is around how the OmniPL cooldown mode works controlling the valve actuator.
When I installed the heater, I know I tested turning the heater on and off and know the actuator rotated the valve appropriately. I did not watch to see what happened with cooldown enabled.
So - I am pretty sure I have seen cooldown mode displayed for the heater, but was not local to see the valve operation. Does anyone know for sure that the OmniPL (omnilogic) waits the prescribed time (default 5 minutes) when cooldown is enabled before shutting the valve off?
I will be testing it after repairing some plumbing - as I found this yesterday evening:
And yes, I know I need to rotate the regulator for more clearance and to point the vent downward. And yes, it is SCH40 PVC that collapsed like that.
-Tom
Check that you don't have the IN and OUT reversed on the heater.
That I am sure about. The non-collapsed is the IN, there is a small black arrow molded into the inlet pointing towards the header. What I *think* happened is the heater was turned off manually using the OmniPL control panel and the valve closed leaving the hot water with nowhere to go. But until I replace the pipe, I cannot test - won't fire it up in the state the plumbing is in. Hope to replace it tonight.
I was just hoping someone here that has extensive experience with Hayward's Omnilogic system (OmniPL in my case) knows how cooldown mode works specifically.
-Tom
The left hand IN pipe shows some signs of collapse. I think they both need to be replaced.
It many be shadows but it looks to me like there is a bulge along the red line and indentations along the blue lines...
Pretty sure that is a shadow artifact.
What I need to know is how Hayward cooldown mode works - does the low voltage relay get opened (turning off heater) then the cooldown time elapses before the actuator on the valve is demanded closed. Or does the relay get opened and the actuator close the valve at the same time.
-Tom
The configuration screen, when gas type was selected, prompted for which low voltage relay and asked if a valve was installed for the heater, I selected the appropriate valve port where the actuator was plugged in. I do know that the controller is indeed turning the valve on/off with call for heat. I have watched it when I manually flip the display to heat on and heat off. So the manual does not seem to match the config screens.
I tested that to get the correct cam settings while I was waiting on the plumbers to get the gas line installed. I did NOT test the cooldown function. I will be...
If cooldown does NOT control the valve appropriately - not sure what to do then. Other than adjusting the actuator cams to always have some amount of water going thru the heater. Which is not really my preference.
Here is the XML file data (config data that can be saved to disk) for the heater, showing valve operations and cooldown enabled (bolded/highlighted in RED:
-<Heater>
<System-Id>20</System-Id>
<Shared-Type>BOW_NO_EQUIPMENT_SHARED</Shared-Type>
<Enabled>no</Enabled>
<Current-Set-Point>86</Current-Set-Point>
<CoolingCurrentSetPoint>70</CoolingCurrentSetPoint>
<Max-Water-Temp>104</Max-Water-Temp>
<Min-Settable-Water-Temp>65</Min-Settable-Water-Temp>
<Max-Settable-Water-Temp>104</Max-Settable-Water-Temp>
<Cooldown-Enabled>yes</Cooldown-Enabled>
<Extend-Enabled>yes</Extend-Enabled>
<Boost-Time-Interval>300</Boost-Time-Interval>
<Heater-Become-Valid-Timeout>900</Heater-Become-Valid-Timeout>
-<Operation>
PEO_INIT
-<Action>
<Action-Function>ACT_FNC_HEATER_STARTUP</Action-Function>
<Action-Data1>0</Action-Data1>
<Action-Data2>0</Action-Data2>
<Action-Data3>0</Action-Data3>
</Action>
</Operation>
-<Operation>
PEO_TEAR_DOWN
-<Action>
<Action-Function>ACT_FNC_HEATER_TEARDOWN</Action-Function>
</Action>
</Operation>
-<Operation>
PEO_HEATER_EQUIPMENT
-<Heater-Equipment>
<System-Id>21</System-Id>
<Name>Gas</Name>
<Type>PET_HEATER</Type>
<Heater-Type>HTR_GAS</Heater-Type>
<Enabled>yes</Enabled>
<Priority>HTR_PRIORITY_1</Priority>
<Run-For-Priority>HTR_MAINTAINS_PRIORITY_FOR_AS_LONG_AS_VALID</Run-For-Priority>
<Allow-Low-Speed-Operation>yes</Allow-Low-Speed-Operation>
<Min-Speed-For-Operation>50</Min-Speed-For-Operation>
<Requires-Priming>no</Requires-Priming>
<Min-Priming-Interval>180</Min-Priming-Interval>
<Temp-Difference-Initial>8</Temp-Difference-Initial>
<Temp-Difference-Running>2</Temp-Difference-Running>
<Sensor-System-Id>-1</Sensor-System-Id>
<Shared-Equipment-System-ID>-1</Shared-Equipment-System-ID>
-<Operation>
PEO_OPEN_VALVE
-<Action>
<Action-Function>ACT_FNC_HW_ACTIVATE_VALVE</Action-Function>
<Action-Data1>12</Action-Data1>
<Action-Data2>1</Action-Data2>
<Action-Data3>1</Action-Data3>
</Action>
</Operation>
-<Operation>
PEO_CLOSE_VALVE
-<Action>
</Action>
</Operation>
-<Operation>
PEO_GET_TIME_VALVE_LAST_TURNED
-<Action>
<Action-Function>ACT_FNC_HW_SEC_SINCE_VALVES_LAST_TURNED</Action-Function>
</Action>
</Operation>
-<Operation>
PEO_GET_VALUE
-<Action>
<Action-Function>ACT_FNC_GET_VA_RELAY</Action-Function>
</Action>
</Operation>
-<Operation>
PEO_TURN_ON
-<Action>
<Action-Function>ACT_FNC_TURN_ON_LV_RELAY</Action-Function>
<Action-Data1>2</Action-Data1>
</Action>
</Operation>
-<Operation>
PEO_TURN_OFF
-<Action>
</Action>
</Operation>
</Heater-Equipment>
</Operation>
</Heater>
-Tom
I replaced the collapsed SCH40 pipe, and tested the heater out today. The OmniPL does turn the heater off and closes the valve at the same time - preventing cooldown flow. That would indeed cause the water in the heat exchanger to super-heat, from the residual heat in the heater and cause the overheated exit pipe.
I have opened a case with Hayward via their online form - to see if this is functioning "as designed", or not. If "as designed", I asked if they would consider a future enhancement to the code to not close the valve until the cooldown time has expired.
For now - I will adjust the cams in the Hayward actuator to allow some flow thru the heater at all times, so when it is turned off, there will be water still flowing to allow the heat exchanger to cool appropriately. Kinda defeats the purpose of a heater bypass valve...
-Tom
Reactions: JamesW
