- Apr 22, 2023
- 52
- Vinyl
- Hayward Aqua Rite (T-15)
Will try that, thanks!It may have failed to properly seat after you last moved it. Try cycling through to other positions (pump off) and return to filter. If leak persists, you likely need to replace the gasket inside.
How to Replace a Spider Gasket on a Multiport Valve - INYOPools.com
How to Replace a Spider Gasket on a Multiport Valvewww.inyopools.com
Less likely is that the plastic of the assembly is cracked. If the plastic is cracked, at a minimum, you'd need to replace the entire valve unit.
Cycled the valve and we went from a drip to a full blown leak. I don't see anything cracked on the outside. Worth disassembling to inspect before ordering a new gasket?It may have failed to properly seat after you last moved it. Try cycling through to other positions (pump off) and return to filter. If leak persists, you likely need to replace the gasket inside.
Cycling through will open the waste port to gravity temporarily. Are you on filter with consistent water flow out waste now? If so, then yes, disassembly to inspect is warranted. Take precautions to prevent the pool from draining while you are inspecting.Cycled the valve and we went from a drip to a full blown leak. I don't see anything cracked on the outside. Worth disassembling to inspect before ordering a new gasket?
Yes, you can't see it, but it elbows over to the SWG.
