Hello Pool People,
I have an issue with rust from exposed metal and I'm hoping someone here is familiar with this problem and has a suggestion for a cheap and simple DIY fix.
I searched all over the forum but seems like there was only one other post with a similar problem but there weren't many suggestions on how to fix it.
Here it is:
When my pool was re-plastered, the bums that did the job left some metal exposed above the skimmer to lay the coping on and same thing above the outlet by the spa. It's probably rebar, but I don't know... and in the pics it doesn't really look like rebar. I've attached some pics that should show the problem pretty well.
My main concern is that the metal is corroding and rusting pretty badly. I'd love a simple solution on how to encase it some how to stop the rust from leeching out all over. It looks terrible. I'm embarrassed when people are swimming and they see it.
Also, I've been battling some stains on the bottom of the pool and now I'm pretty sure it's from this rust in the water. I've scrubbed them with a metal brush for weeks on end, same thing last year, and they have barely budged. Pool store test shows copper in water is 0.4ppm. I was thinking of doing an Ascorbic acid treatment but I definitely need to deal with this rust first.
Any ideas?
Thanks!
Here it is:
Any ideas?
Thanks!
