- Oct 25, 2015
- 5,321
- Plaster
- CircuPool RJ-60 Plus
Folks, my pool that is under construction has pool pump Arrangement that is a little different than normal. The main pump is a 5 HP Pentair commercial pump and I have a separate dedicated pump just to run the filter. I would like to use one of the inexpensive Dohenys variable speed pumps. In normal operation it requires you press the Run button to start the pump which doesn't work very well with my automation. However they describe an external only mode control in the manual with no definition of what this is how to invoke it. Does anybody have one of these pumps and can you provide some information about how it works? I would like to be able to turn power on and off with my automation and just have it start at a default speed that I can set. Then turn the pump off after a period of time.is
Any help would be much appreciated.
Chris
Chris
