- Nov 12, 2017
- 11,997
- Plaster
- Pentair Intellichlor IC-40
For all with an auto-leveler or any sort of overflow port in their pool:
After that last big California storm, I noticed my pool's water level was very high. Too high. The level got above the outlet port of my auto leveler. I now recall I saw its pipe full of water a while back, but for whatever reason that fact didn't register that there was a problem. Obviously there was a blockage somewhere.
So I temporarily fitted a hose to the outlet port, "temporarily" being the key word there, then proceeded to turn the hose's nozzle on. I let go of the hose after doing so and it promptly popped off the pipe and drenched me head-to-waist. Fun times.
I tried again, this time holding on to the hose, and after a few spurts got the flow going. At the same time the other end revealed itself where it comes out in my yard. I proceeded to investigate that end and found it all covered with dirt and roots and overgrowth. I cleared all that out and restored the flow. I will later extend that pipe so that it can't happen again.
Just a reminder, if you have such a setup, to run some water through it and make sure it is not on its way to getting clogged up. Check the end to be sure it is clear. That flow is not under pressure, just gravity, so it doesn't take much to plug it up.
I lucked out, in that I noticed it before the pool overflowed. But Murphy's Law specifically states that should blockage occur, enough to cause the pool to overflow, it can only happen at night, while it's pouring, and just after you've put on your nice, warm jammies. ("Jammies" is actually how it is expressed in the ML text.)
Check it soon, before the rains start in earnest.
