- Jun 1, 2018
- 14,088
- Vinyl
- Hayward Aqua Rite (T-15)
Definitely try to get as much organic debris out of the pool as possible via scooping & vacuuming- the more you have in there the more rapidly the pool will consume fc.
Scooping & vacuuming blindly is fine.
Vacuuming to waste is a good idea in the beginning when the stuff is super funky to get the bulk of it out of the equation. This takes some of the load off the sand filter.
Later on vacuuming to filter is just fine.
You may also want to get an inline leaf catcher for the vac hose to prevent any clogs in your plumbing if you suspect larger debris.
As mentioned above be sure to note your clean filter pressure (After backwashing) at the rpms you’re running. You want to backwash when pressure rises 25% over that number.
SLAM ON
SLAM ON
